i have done this to my 91 supra before. first of all all flip light cars have knobs on them that you can manually adjust just incase one of your flip lights fails to flip. this knob can be found right by the light under the hood(inner side of the light). my knob has a rubber cap on it i am not sure about yours. before you start adjusting you need to disconnect a wire also right next to the light so that the lights will stay the way you want them and not flip up and down. this wire has a quick disconnect on it all you have to do is disconnect that and they will not flip up and down. the wire is pretty easy to find, its like the only wire by the light(on the inner side of the light). if you decide to do this in the wintertime i suggest covering each of the quick disconnect ends so nothing gets in there and ruins your connection. also i suggest using a ruler to get the correct measurement of how far each light is.
let me know if you have any more questions about this
