Try to be a lot more clear about just what you are describing;
"afterwards my friend told me to turn it on, on the air to see how they sounded"
Don't understand that one.
Also: "then i looked around and noticed that my brake oil and power steering oil overflowed and was all over"........................?
They both use different types of "fluids". The power steering reservoir is on the exhaust side so I can see how it might overflow and spill on the exhaust. And when redoing the brakes, the brake reservoir fills back up when you compress the calipers, but don't know why it would get on the exhaust.
Best guess, brake booster somehow got brake fluid inside and when the engine was started it sucked the fluid into the intake and burned out as white smoke, but as far as why the wetness on the exhaust, no ideas.
Russ
