Since I sold the parts for this already, I would know (although the parts I sold were for the MKIII).
5 Speed tranny
Bellhousing with inspection plates
Clutch fork
Gear shifter
(on the MKIII, you need to change the first propeller shaft, not sure about the MKII)
Clutch pedal
Brake pedal
Clutch master cylinder
Clutch hard and soft line (all that go to the slave cylinder)
Clutch slave cylinder
Flywheel
(on the MKIII, you need the engine block to transmission "wings", not sure about the MKII)
Things you may buy yourself since you have it all apart
Clutch
Throw out bearing
Pressure plate
