Originally Posted by eternal genome
another question: my battery shifts in its little tray and when i take a turn it will slide and sometimes when it does my car shuts off. Then i get out, pop my hood and pull the battery back over to the left side and it comes on. what do i do?
well... if you battery keep slide like that then first try to tight up your battery first... and see if that solve the problem... cause sometime the positive term. can attach to the body frame... cause the body frame is negative... and when the battery slide to the left side and the positive term. can attach to the radiator... and your car can have a shock... and thats why your light is dimn or the car is die.... so try to tight up the battery first.... hope this works for you...
another suggestion... when you step on your brake and your light is dimn or low on elect. then sometime it can be your alternative to.. cause its poor and it didnt have a good charge/run... so thats why you kind of low on elect... so try to test your alternative by brought it to a nearest shop close to you for a test.... cause its free for testing... so why dont you do so...
