Old 02-27-2006, 11:57 PM   #10
hangsupra
Originally Posted by eternal genome
Last question: I smell exhaust vapors in my car when i drive, and i smoke and i dont want to die. SO, do you think its a leak in the exhaust, muffler, gas tank, or what?
some if you low on oil and when you step on the gas then it gave you smoke and you can also smell oil tho... so check on your oil's also.
if your exhaust is leaking then you can feels by step on the gas pedal while you drive.... when you step on gas pedal... if your car make lots of noise and you didnt gain any accelaretion or if you didnt see your car speed up quick and you hear your motor makes lots of loud noise then you have a exhaust leak somewhere under the down pipe or muffler tho....
another suggestion is that.... sometime when your cat. converter is not good and those thing inside the converter is torn apart by pieces by pieces then it does give you that problem too... so another thing you can do is try to untight your exhaust and take a look inside the converter see if those those i dont know what they call but if you see inside the converter and you didnt see anything and all you see is a light on the other end then it means that its bad need to replace that and it solve the problem... sorry if i didnt makes anysense alright... cause i just got back on this forum... so i kind of slow this day... but please correct me if i wrong and didnt make sense alright. thanx.
