it use to happen on my other 85 mk2 supra... and i check on the fuse on the fuse box... and it runs a bigger fuse so when you acceleration then the battery went up or goes up... and replace by the stock fuse then it solve the problem.... so try to check on the fuse... and see that helps you.
