what kind of noise... is it like a knocking noise or like someone who hammer the tranny from under the tranny.... is that the noise you hear.... if so then the problem you have is the flywheel... cause its not tight tight to the block.. i beat you that the bolt that holds the flywheels to the block is loosing....so you need to tight it more tightly..... hope this the proble you have... that use to happen on my mk2 when i do a auto/manual convertion.... i convert from auto to 5speed and thats the proble i having on my mk2... so double check the flywheel....
