Thread: 3 cars vs supra
Old 02-28-2006, 01:46 PM   #18
rnoswal
rnoswal's Avatar
Valve covers, front or rear oil seals, oil galley plug front or rear, oil pressure sender unit, dipstick tube, oil filter, oil drain bolt, front or rear seal on the transmission, could also be the power steering pump or hoses feeding it or the rack itself.
Transmission, engine and power steering pump all use different fluids, so if you can narrow it down to what type fluid and the area it is pooling, up front, left or right side, back where engine/trans meet.
As you can see there a plenty of possibilites so try to narrow it down some if you can.
Let us know
Russ
