Well like I mentioned before, if you have the studs then they are such a close fit that what happens is that the alignment holes, the 2 holes that fit over the short studs at either end of the block, have to be elongated just a bit. For some reason, some of the aftermarket head gaskets are a little long in that area. The gasket will fit over the studs but it is press a liitle here and then a little there to make it slide down to the block.
Russ
