well the cvar is originally manual, so im pretty sure its not a porblem that would arise out of conversion. My transmission had been wearing out, being that its an 83 and therefore it was 20+ years old. Eventually, one day, about a cou0pel weeks ago, i turned on the car, and when i let the clutch out, it sounded like theres was a loose nut being tossed around inside the engine, sounded VERY loud. The nhoise goes away when i push the cluth in. Replaced the clutch, and now theres stiull a wierd sound, im sure is the throw out bearing not backing off enough when the clutch is out while in neutral. I think today i heard a bit of a knocking sound, but that was only today i heard that. The noise, it almost seems, to be a little biut different everyday, which is why tis hard for me to figure out exactly whats going on. I know the clutch still needs to be adjusted because it shits VERY roughly right now too. Sometimes i have to really push it into 1st, sometimes i works easy, and often getting grinding as well. I figured the easiest and most headache free way would just be a new tranny, unless i can fix it with less money and/or work.
