That knock may be the rear bearings..I thought it was my tranny at first also..Do yourself a favor and drop the tranny and clutch and make sure the flywheel is torqued down then put on the bellhousing by itself..Put on the starter and fire it up..You will find out pretty quick if its the mains or tranny..Even if the motor was recently rebuilt check anyway..I just got to the 4000 mile mark and the motor is knocking agian..
