Originally Posted by Dom
i have a 95 twin turbo recently i noticed oil dripping from intercooler would anybody be able to give me any info on this thanks
Most likely it's not an issue (depending on the quantity) and the oil is coming from your PCV system. Worst case you've either got excessive blow-by in one or more of your cylinders or your turbo seal(s) are leaking. I'd suggest starting with a compression test, and also consider routing your PCV hose(s) through a catch-can.
