For Supra91
Is there a mount for the O2 sensor on your header? I just installed a new sensor to pass emissions here in NJ. They test you every 2 years. I see you live in Conneticut, or as the truckers say, the Communist state. Jersey is pretty much the same. Are you saying that you have to reinstall the stock manifold just to pass inspection, or is it that you can't get your emissions down enough with your set-up? I would definitely not want to reinstall the manifold every 2 years, no f-in way. Anyway, my water pump just crapped out on me and my baby's in the shop right now. After that, I need to replace the valve cover gaskets. So it will be a while before I seriously contemplate the exhaust upgrade. I really appreciate all the input you can give me Supra91, thanks a lot.
James in NJ
