I found that coolant bypass line in the lower air intake manifold and I put a new gasket in (lower aic gasket.) and the hose didn't look bad at the time but I am going to change that out now and see if that helps.
There is no rust on the block at all just the paint and I can't see any leak but I'm no expert and in the time it takes me to rip the car down enough to see weee the heat from it has dried away any evidence and I can't find any residue spots left behind or anything.
Would the frost plugs be hard to change out?
And thanx alot for your advice I'll try the hose right off and go from there!
