Old 03-09-2006, 04:49 PM   #1
Isphius
Isphius's Avatar
what celica do you have exactly? im not sure on their body codes. if its rwd, and the engine will fit physically (its not to long), it shouldnt be all that hard to convert. just have to make/get made custom engine mounts and maybe redo the trans cross member. and if the driveshaft should fit, but if it doesnt it doesnt cost a lot to get a new u joint put on it and have it shortened. any automotive machine shop should be able to do that. If its an automatic its easier, but if its a stick youll have to get the clutch master cylinder or linkage and pedal from the 5m car. also the speedometer might not work with a new transmission, so you may have to find one of those, and the shifter might come out in the wrong place so itll feel weird and u may haev to modify the interior.
