HELP with 7mGTE
Hey guys how are we all?
im new to the forum and would like some advice.
i own a ma70 supra, i was forced to remove my turbo kit in order to pass registration. the car was idoling perfectly before i swapped bak to a STD CT26 turbo and manifold.
Since passing reg and refitting the aftermarket turbo bak on... (TD04E HKS KIT) The car has had poor idol.
I belive it is the way i refitted the Distributor / Crank Sensor. (is this wat its called?) Is there a set procedure into refitting this part??? Is there A WORKSHOP spec from TOYOTA??
i DID mark the gears in the sensor prior to R&R and put bak on as accurately as i could.. Still Bad IDOL ;-((
Any help would much appreciated. Im excited to be a part of this big community.
Cheers
Barry
