The starter relay, if I remember, is on the passenger side kick panel. You'd have to remove the plastic cover (there is a nut on a stud that holds it in) and the junction block is along the right under the glovebox. If I recall correctly, the OEM starter relay is a green relay, four pins, square in shape. I'd post a link to the TSRM, but they're down at the moment. I know it's listed in the Body Electrical section.
--Nick
Black '87 N/A Auto
