Thread: A/C question
Old 03-13-2006, 02:46 PM   #1
rnoswal
rnoswal's Avatar
Question A/C question
I have an 87 turbo and an 87 N/A. The N/A's A/C stopped working, but it was just a fuse. I thought it might have been the dash unit at first though for some reason and tried a few different ones I had. They all worked fine as far as speeding up the engine when the A/C was turned on and once I replaced the fuse all was good.
Now my Turbo is another story. If I turn on the dash A/C button, nothing at all happens, so I tried the other control boxes and they all reacted the same, nothing happened. If I hot wire the compressor it works just fine. When I got the car the A/C wasn't woking because of a bad compressor. I replaced it and charged the system.
Is there a fuse for the A/C or another controller I am missing? The same fuse in the N/A is working in the turbo, but the panel doesn't say A/C fuse, neither did the N/A panel for that matter.
Any clues out there?
Thanks
Russ
