Old 03-14-2006, 11:08 PM   #2
Supra-Boy
Supra-Boy is on a distinguished road
Smile
Originally Posted by suprra_girl
what have you done to verify you have spark?
did you pull a lead out and try one of "your" plugs in it or did you use a spare plug you have
if your plugs are firing
that means the plug won't be wet as the fire evaporated it
how many cylinders did you check... all of them?
check all your plugs to make sure they aren't faulty
Well I took off spark plug from #1 cylinder and put it on valve cover and crank up engine it fired.. and last cylinder #6 and it fired too, I used spark plugs that were in the car not spare ones... and it even sparked when I put the wire with plug on the valve cover without the spark plug...
Thank You for your help!!
Supra-Boy is offline   Reply With Quote
