Originally Posted by suprra_girl
are your cars turbo?
have you both done diagnostics?
check for boost leaks or check the air flow meter is correctly plugged in
have either of you done the 12 volt mod to the fuel pump?
my car is not a turbo. 86.5 NA
i havent done a 12volt mod to the fuel pump. and the AFM is plugged in properly as well. mrnickleye said it could possibly be an EFI or ECU problem. I know mine is not a vacuum leak, I replaced every line and nothing leaks. My fuel filter was changed not too long ago as well, and the problem persisted.
