Old 03-17-2006, 02:31 PM   #1
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by Dom
i took off and cleaned out intercooler and all pipes definatly need new intercooler but after two days i had a steady leak again iwas talking to turbo dynamics uk and they reckon i have a crank case breather problem...
I'm glad to hear they agreed.
...i had motul 5w 30 oil in car they think this could hav sumthing to do with it...
Although I doubt this is related to your oil leak, but you still should be running 10W30 as per Toyota's specifications. The correct, permanent fix to the PCV-oil problem is the installation of a catch-can.
...what you think about intercoolers on ebay?...
Generally speaking, they suck. They usually don't come with piping, mounting brackets, couplers, clamps or a warranty.
...and do you know where i can get diagram on crank case breather...
It's a very simple system. There are two breathers - one with a PCV valve on the left side valve cover (attached to the intake plenum), and another on the right side valve cover. There are also two hoses going between the two valve covers. That's it. What kind of diagram were you looking for?
Life begins at 30psi.
