Thread: help?!?
Old 03-19-2006, 10:19 AM   #2
djalkyd
djalkyd's Avatar
djalkyd is on a distinguished road
start with fuses then check if a ground is loose. check your main ground wire from the battery, if that one is good then check the grounds from the starter and block to frame.
djalkyd is offline   Reply With Quote
