Originally Posted by SupraTT/Iceland
...The FCD seems to work fine. No fuel cuts anyway.
Yes, but it'll wreck your oem twins. More info here:
http://www.mkiv.com/techarticles/bcc...GReddy_BCC.htm
...I?m maybe thinking of upgrading to a larger turbo and fuel system in the summer.
Unless you're going to a HUGE turbo (74mm or larger), you won't need head studs...the oem head bolts work fine.
