Take one to a good automotive speed shop. Let them measure it and test it for spring pressure at different heights. They might be able to match one up that is for higher performance and a little cheaper too. Stock springs are pretty good and with stock pistons they will not touch the pistons nor each other, even if the cambelt breaks. It is a non-interference setup stock.
Russ
