Sorry, you said N/A so no wastegate on it! Check out fuel pressure, ignition, or even the AFM. Is sputtering the same as missing? Make sure your distributor connector is plugged in tight, but if it is missing occasionally then it sounds electrical and may just need a good tune up.
Russ
