Oil prssure gauge
I had the same problem. It is the gauge itself. There are a couple of components to it (a spring and a brace) and one of the pieces simply breaks off. You can get one from a used instrument cluster (that's what I did) as it is only slightly more than the gauge itself, plus leaves you with additional parts if needed.I have one laying around (damaged) if you need pics to see what is broken.
