Old 03-24-2006, 05:33 AM   #2
Burn N' Up
Burn N' Up's Avatar
All gear ratios different except 4th 1:1 and the W58 has less gear lube. W58 also has much larger clutch assembly andfly wheel as well as a "press in" clutch fork design as opposed to the more compact but much more comlpicated "pull out" clutch fork set up that is in the GTEs R154
