Head Bolt Retorquing
When replacing a BHG with a stock or Fel-Pro gasket, has anyone retorqued the bolts/nuts after a few heating/cooling cycles? Did they move at all? I want to determine if these non-metal gaskets crush down a bit after heating a few times.
"You see, wire telegraph is like a very long cat. You pull his tail in New York and his head is meowing in Los Angeles. Do you understand this? Radio operates the same way: You send signals here, they receive them there. The only difference is there is no cat." A. Einstein
1988 and 1990 Turbo Supras
