Old 03-27-2006, 01:13 AM   #1
Benesesso
Benesesso's Avatar
Benesesso is on a distinguished road
Default Bolt Identification
I am in the midst of a dreadful BHG fix on a 1990 Turbo. I took a lot of photos, but they were nowhere near enough. Also put all the removed bolts and nuts in labeled sandwich bags.
So after I get the "intake manifold" bolted back on the head, I find all the bolts in the photo left over--from the bag "Intake manifold to head".
I have another bag of bolts for the "outer" manifold-or whatever it's called, so these in photo aren't for that.
Any ideas on what they're for? The longest is 32mm from under the head to end (8 mm bolt), and the shorter fat one is 10 mm dia. The other photo is the horrible jungle of stuff I mhave to sort out.
I don't want to go any further with the reassembly until I find out what they are.
NEVER AGAIN!
ID:	196   Click image for larger version
"You see, wire telegraph is like a very long cat. You pull his tail in New York and his head is meowing in Los Angeles. Do you understand this? Radio operates the same way: You send signals here, they receive them there. The only difference is there is no cat." A. Einstein
1988 and 1990 Turbo Supras
Benesesso is offline   Reply With Quote
