Old 03-27-2006, 04:50 PM   #2
stuck1
stuck1 is on a distinguished road
it sounds like you have a vacuum leak somewhere, maybe an
intake gasket? might want to spray some brake clean over vacuum lines and where intake meets cylinder head while vehicle is running. if idle stabalizes when you spray a certain area then
you found your vacuum leak. if not might want to check tp
sensor
stuck1 is offline   Reply With Quote
