hey there
thanks for the reply, the compression test will be done on thursday by a mech friend of mine
hopefully the numbers come up good. also, since you mentioned a block test... how is that done?(total newbie here sorry) would it require removal of the engine???
cleaned up the engine with degreaser today... if it was only possible id clean the whole thing with a toothbrush...
still waiting for some signs of oil leaks whatsoever.
im gonna hang around for a while to see what i can learn from you guys if you dont mind
cheers....
-edz
