Thread: NA to TT swap
Old 04-02-2006, 02:27 AM   #11
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by razerback121
The Sad truth.....
I recently purchased a JDM 2JZ-GTE Rated @ 280 hp. I was going to leave the engine J-spec because.....its easier like that to just drop it in. Unfortunetely there are no connecters that go from the engine to the Engine bay fuse Box. Furthermore there is a connector on the harness that does not fit anywere onto the Us-Spec supra. This connecters consist of some 60 wires.....Also 2 of the 3 connectors to the ECU are present on the wireharness. The third either connected another ecu or was just imbedded in the j-spec body.
It looks like im going to return the engine to the JDM depot or cought up around 6 more g's to get the engine stripped down and rebuilt to US-spec. I got lots of pics of it if anyone wants to see. I assure though, to the average mechanic its hopeless.
Please do post the pictures.
I'd also mention that the VAST majority of JDM 2jz-gte's available for sale in the US are from Aristo's (and not from Supras). As a result, there are a few physical differences between the two engines, including the oil pan.
I agree it's a tough project, but doable for a good shop experienced in Mkiv Supra Turbos. For example, I've personally seen a number of these completed Mkiv Supras with US NA->JDM TT from AAP Motorsports in Atlanta, Georgia, US. Again, it's doable but I agree it's far from an easy project.
Life begins at 30psi.
