Old 04-02-2006, 02:29 AM   #13
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by Dom
i done a compresion test on my car all cylinders are 150 psi is this ok ?plugs were a bit oily the cylinder closest to bulkhead was worst
Are all of the cylinders EXACTLY 150psi? That's very unusual...are you sure you did the compression test properly?
If the plugs are oily, you need to replace the valve/cam cover gaskets and the grommets on all of the bolts and studs that hold the valve/cam covers down, according to the steps in the TSRM. This problem has nothing to do with oil in the intercooler.
Life begins at 30psi.
