cooler is kool
Does the tranny oil run into the radiator??? If not, the add-on cooler must be VERY big to cool down the oil. In fact, you may want to put one of those coolers on that come with its own fan.
As I'm sure you are aware, for every 20* temp drop (cooling) of the tranny oil, you will double the life of the trans. Trannys generally run at about 170*.
http://www.perma-cool.com/Catalog/Cat_page02.html
