check all your fuses first.... and replace all the broken fuse first. after replace all the problem fuse. try to put the key on n turn till the ign. on but dont start the car. and see if it work. if it work then try to start the car. if the car crank and wouldnt start or it start and die in awhile due to a brakelight comes on the cluster. you need to replace your alternater. cause thats what i do on my way back in the day when i first got my mk2. hope this work. want to know more email me @
rare-rider@hotmail.com and i give you more info. where to check n do...
