I think the most common early head gasket problem is from the combustion chamber to a water passage. Think of it this way, the combustion pressures are far greater and hotter than either the oil/water pressures/temps while the engine is running...remove the radiator cap while the car is running, and see if there are any bubbles in the coolant... if "yes" ,increase the rpm, and see if they get worse...if you don't have water in the oil, you can probably seal it with any of the "solutions" they sell for fixing this type of gasket failure before the combustion gasses erode the gasket to an oil passage.
