Old 04-10-2006, 12:00 AM   #3
midwestmk2
midwestmk2's Avatar
You will have to relocate the radiator to the front of the support for it to fit..The RA65 uses the same suspension,tranny,etc..Except that it has a shorter wheelbase and some came with solid rear end not the IRS..So the 5MGE will fit just little mods like the radiator,motormounts from a supra,ECU,all sensors and the MAF plus the harness..So if your friend goes through with it just get the engine,tranny,driveshaft and everything else and your in buisness..If you have a solid rear axle you wont be able to use the driveshaft..On your friend he will have to do alot..Fab custom motor mounts,custom exhaust,custom tranny crossmember,custom driveshaft,etc,etc,etc....Wow the work...
P.S. dont save for a MKIII they are PIGS...
