So, then, what you are saying is that you are using a cooler that has NO seperate fan, and is only about 12"x6"x3/4", right?
Without running the oil into the radiator (which, by the way, coolant disepates heat 10x quicker than air), or one with its own fan, you need a cooler the size of your a/c condensor (in my opinion).
