Stopping the Heater!
Heat flows into the interior of my 1990. The little valve at the back of the pass. side engine compartment moves as it should. HOW can I stop the heat? Also, there isn't much outside airflow into the interior.
Hope this is something simple.
"You see, wire telegraph is like a very long cat. You pull his tail in New York and his head is meowing in Los Angeles. Do you understand this? Radio operates the same way: You send signals here, they receive them there. The only difference is there is no cat." A. Einstein
1988 and 1990 Turbo Supras
