The digital temp. is set all the way down to 65. There is probably something wrong with the air inlet valves/baffles/whatever they use. I hope it's just a vacuum line or something simple.
"You see, wire telegraph is like a very long cat. You pull his tail in New York and his head is meowing in Los Angeles. Do you understand this? Radio operates the same way: You send signals here, they receive them there. The only difference is there is no cat." A. Einstein
1988 and 1990 Turbo Supras
