Originally Posted by Dom
Hi Phil i was just listen to the infamous death whine on mkiv.com that noise has been steadily growing in my car past few weaks ,thats all i need.
still waiting on my gaskets,grommets and catch tank to arrive .
Ive been on mvpmotorsports a bit and i like the look of the PHR stage 1 turbo kit i could just about come up with that sort of cash if need be ,if i did would i get away with just upgrading the fuel pump and fuel pressure reg.?they also mentioned removing mass air flow?
Iwas thinking of changing my rims ,not any more.
You won't need to remove your maf, imo. As long as you keep it below 600rwhp (6spd) you can get by with (only) a fuel pressure regulator upgrade. It's critical that you keep it below this point, even including boost spikes and boost creep (i.e. don't set it for 600rwhp max/average, with peaks up to 625rwhp, for example). Of course, be sure to run a sufficient octane of fuel for the boost level you run it at.
With the aftermarket (adjustable) fpr in place, set base fuel pressure to about 55psi or 60psi, and then reduce fueling 0-3500rpms accordingly (using an AFC, emanage, or map ecu)...and then dyno-tune with care.
