HAD the same problem
i bought a 7mge from enginelandinc.com got here and was messed up bad oil pan dented distributor busted along wiht throttle body, wireing harness just cut..so i got them out switched all the parts from my old engine liek the throttle body motor mounts and so on. as for the wiring harness i used my one of my 87 some of the plug in were diff. like the ones for the fuel injectors, those i just used my old injectors. the one of hte distributor was different. and you must use your old distributor u can't just splice the wires it'll start but not run.(be very careful with the changing of the distributor you can bend valves if put in wrong) and also i spliced the wire to the sensor on the block that is down by the oil filter. you can make it work if you have spare parts and lots of lots of time. good luck let us know how it goes.
87 N/A with a new JDM 7mge.
Looking for a 7mgte
