Old 04-14-2006, 01:36 PM   #3
newtome
newtome is on a distinguished road
I've pulled the fuse to reset the ecu and started the car and it runs the same I've done it with the jumper and with out the jumper and it does the same.with the jumper in it will flash code 51 only when I try and give it gas and when I let off code 51 goes away.
newtome is offline   Reply With Quote
