Thread: brakes
Old 04-16-2006, 06:25 PM   #10
Isphius
Isphius's Avatar
replace the brake booster and its vaccum line. Or check the vaccum line connection going to the intake. Most cars have vaccum power assisted brakes, if theres no vaccum in the booster, you dont have assited braking. Try this, pump the brakes a few times with car on, turn it off, and pump them a lot more times. if nothign changes (braking gets harder, softer, anything) than you probably have a vaccum booster problem. A good booster should hold enough vaccum after the car is off for 2 or 3 or 4 pumps(Its an emergency feature)
