Well, I think he has respect for his car just as you do. I also think the the Lexus afm does of course allow for more boost but I also think that up to the limits that the original let the car boost, is also a safe limit for the larger Lexus afm. Sure it will allow more air, but 10lbs boost is still the same now matter how big the afm is. But because it will allow much more boost than stock you have to limit your boost to a safe level, but bigger injectors and fuel pump are still the way to go to be safe I realize.
Correct me if I am wrong though.
Russ
