Old 04-19-2006, 12:44 PM   #13
ddmcse
ddmcse's Avatar
thanks !
sounds like DIESEL truck idling doesn't ?
Sooo ... afm + injectors from a Lexus ls400 v8 ? no .
i do not know about the lexus injectors working
it's the lexus air meter you want .
http://suprasonic.org/sonic/sonic.htm
go here scroll down
ALSO
for those that might also be wondering about the electronics of each AFM
quick search and came across this
Hello all! Its been a long time since I've written in, but I'm still
here
> > quietly enjoying the conversation in the background...
> > Anyhow, as the subject says, I would like to get a definitive answer on
the
> > Lexus AFM electronics.
> > My current (stock) AFM is on the fritz, and needs to be replaced. I want
to
> > do the Lexus upgrade someday, but not right now. -So, I'm thinking I
might
> > be able to get a whole Lexus AFM, then swap the electronics over to my
> > present AFM housing until such time as I want the larger Lexus AFM
> > housing....
> > I've read conflicting stories on various websites. Some people say the
Lexus
> > AFM electronics are identical. Others say you must swap out the Lexus
AFM
> > electronics with your Supra's stock electronics.
> > Which is correct? Is it possible that some Lexus AFMs have electronics
to
> > match our own, while others do not?
> I have used the electronics interchangeably without any apparent issue,
but I
> nore Reg Reimer's comments from here...
> http://www.supras.com/~riemer/lexusr...exusnotes.html which says "The
> Karman Vortex Electronic Sensor The electronics module on the Supra and
the
> Lexus air flow meters have numerically different part numbers but are
> dimensionally exactly the same size. Due to the part number difference on
the
> electronics module on the 7M-GTE and Lexus air flow meter, I only
recommend the
> use of the aluminum body of the Lexus air flow meter for this upgrade.
The
> electronic module from the stock 7M-GTE's air flow meter should be mounted
onto
> the Lexus air flow meters larger aluminum body with the three small
original
> Phillips mounting screws".
> Your choice I guess.
> Cheers
> Tony
300+ RW HP Dyno run,
Blown HeadGasket info
My Supra KiXGaS
