It seems that by unsoldering the two diodes inside the light housing, and resoldering them fixed the problem somehow.
As far as the mystery lever that was broken, its for the seatbelt so you can take the seatbelt off easier when the door is open without it ratcheting up. Its broken still so i think i need to get that replaced because at the moment the seatbelt doesnt ratchet or lock up under tension <_< which definitely isnt good if i get in an accident haha..
Ok thanks for the help guys!
