well i found the leak . sort of
after putting a cup under the leak in front of the right REAR tire and allowing some of the fliud to collect, i find that it's not brake fluid ,, it's radiator fluid .. sob.
i by-passed the heater core and the leak has stopped . from what i've read it looks like a bit of a project .
btw the manual does show 4 resevoirs. hell if i've ever seen them and maybe they mean the abs block . course they do have a asection just for the abs brick .
oh well i don't know if i'd rather have a cracked brake line in the body/frame or a leaking heater core . i guess the heater core is the winner , cause by-passing brakes isn't really an option hot or cold climate
