The cooling system will be fine, just make sure your oil cooler is good to go and the turbo will be happy. If your new to turbos you should know that you never drive and then shut down, always let the car idle a bit to blow off extra heat and get the turbo temps into the right range, otherwise you shut the car off and bake oil in the turbo. Change oil at least every 5K and if your being rough on her the manual recommends 2500. Flush the coolant system and make sure everything is running right there. If you just got the car catch up on the basic maintenance, brake fluid, tranny fluid/gear lube, rear end, etc. the 7MGTE is, like alot of Toyotas, very over designed so its solid even with upgrades and abuse.
