Thanks. My local high-perf. muffler shop says they'll make me a new pipe w/SS flex joint AND install it for ~$140. Only the joint will be SS.
BTW, after I got the rear cat. off I looked thru it--looked fine. I noticed that it seems to have a pretty big flow area, so I guessing the muffler has the most restriction of the whole exhaust-esp. since I opened up the entire elbow ID with my die grinder.
"You see, wire telegraph is like a very long cat. You pull his tail in New York and his head is meowing in Los Angeles. Do you understand this? Radio operates the same way: You send signals here, they receive them there. The only difference is there is no cat." A. Einstein
1988 and 1990 Turbo Supras
